branskyj Posted May 13, 2013 Share Posted May 13, 2013 Hi guys, I cannot understand what I am doing wrong but the sun itself (the bright dot representing it) is not visible in my renders. The sun is on and illuminates the scene correctly (if I were to change the intensity the scene brightness changes accordingly). In global switches Lights are ticked on (Off with GI) I am using VRayPhisicalCamera (Apperture 10, Shutter 100, ISO 100) Nothing is blocking the Sun, Show Safe Frames is ticked and I can see the Sun in the viewport. I use the default settings for the sun (Turbidity 3, Ozone 0.35, Intensity 1, Size multiplier 1) My scene comprises of sea surface (2500 meters wide/2500 long plane), then under it I have a sand bottom etc. Any ideas how to get the sun back? Thank you very much. Link to comment Share on other sites More sharing options...
branskyj Posted May 13, 2013 Author Share Posted May 13, 2013 Oops. Got it- I have the DefaultVRaySky in Environment Map replaced with custom HDRI map. Thanks anyway Link to comment Share on other sites More sharing options...
