Tom Bussey Posted May 14, 2013 Share Posted May 14, 2013 I am having a real problem trying to use the conform tool to get the Editable poly in this file to take the shape of the plane below it. I select the poly, select the conform tool from compound objects and then pick the plane as the Wrap-to object. It has a think, but takes no effect. If anyone can figure it out I'd be very appreciative as I've been stuck on this all evening. here's the file: https://www.dropbox.com/s/42sbb3jbrvfcf3g/problem.max Link to comment Share on other sites More sharing options...
Jose Negrete Posted May 17, 2013 Share Posted May 17, 2013 how did you generate the tiles? Link to comment Share on other sites More sharing options...
Tom Bussey Posted May 17, 2013 Author Share Posted May 17, 2013 They were drawn up with rectangles, turned to editable spline, re-sized and tiled. Link to comment Share on other sites More sharing options...
Jose Negrete Posted May 17, 2013 Share Posted May 17, 2013 Hey, Got it to work by generating a new terrain. What I did was select all under edge selection mode and generate spline from selection (line128)... Then generate terrain from those splines. Then conform your tiles to the new terrain. Link to comment Share on other sites More sharing options...
Tom Bussey Posted May 19, 2013 Author Share Posted May 19, 2013 select all under edge selection mode and generate spline from selection (line128)... Then generate terrain from those splines. Sorry, can you elaborate on this a bit? I'm a real amateur and not really sure what you've done here! Thanks. Link to comment Share on other sites More sharing options...
Tom Bussey Posted May 19, 2013 Author Share Posted May 19, 2013 Ok, don't worry, I've got it to work by just drawin a new terrain from scratch. That previous one was only arbitary and was overly complicated anyway. Link to comment Share on other sites More sharing options...
Jose Negrete Posted May 20, 2013 Share Posted May 20, 2013 Hey, What I did was select the existing terrain object and selected all its edges in sub object edge selection mode. I then generated a new spline from the edge selection. Then I created a new terrain from the spline object. Terrain tool is under the compound objects and works with splines. Link to comment Share on other sites More sharing options...
