frockhell Posted May 15, 2013 Share Posted May 15, 2013 hi guy! recently i'm encountering a problem with my autocad 2010. it seems like i can't drag and select item.:confused: And i can't seem to find the option to change my crosshair. :confused: i've uploaded a screenshot for your reference. thanks in advance for your help. Link to comment Share on other sites More sharing options...
frockhell Posted May 15, 2013 Author Share Posted May 15, 2013 i after resetting the profile, my cursor change to this. but i still can't select precisely and can't drag and select. thanks for the help.... Link to comment Share on other sites More sharing options...
salvador Posted May 15, 2013 Share Posted May 15, 2013 Go to Options (op command) then go to the Selection tab and change the Pickbox size. Also, make sure you have your view in Top View (view command) In the Display tab of the options dialog there is an option to change the crosshair size as well Link to comment Share on other sites More sharing options...
frockhell Posted May 16, 2013 Author Share Posted May 16, 2013 thanks bro. but i still can't drag and select. Link to comment Share on other sites More sharing options...
H A Posted May 16, 2013 Share Posted May 16, 2013 Autocad->options->selction tab->remove tick from "use shift to add to selection". Should do the trick. Link to comment Share on other sites More sharing options...
frockhell Posted May 16, 2013 Author Share Posted May 16, 2013 still the same bro. Link to comment Share on other sites More sharing options...
H A Posted May 16, 2013 Share Posted May 16, 2013 Woops, didn't look thoroughly through your settings. You need to turn om implied windowing Link to comment Share on other sites More sharing options...
salvador Posted May 16, 2013 Share Posted May 16, 2013 Shift + Right-click anywhere in the drawing area and click Osnap Settings. Go to the Snap and Grid tab and check Isometric Snap is not active and the activate Polar snap. Post back. Link to comment Share on other sites More sharing options...
frockhell Posted May 20, 2013 Author Share Posted May 20, 2013 it's a goddamn virus... thank god it's back to normal. After i ran a full scan using Kaspersky, there's a virus attached to acaddoc.FAS. After removing it and reinstalled AutoCAD, it's all good to go now. Thanks guys for all the help. Appreciate it. Now back to work. Link to comment Share on other sites More sharing options...
