marcinleita Posted May 20, 2013 Share Posted May 20, 2013 my first question around here hello everyone! i'm creating a still showing a nature scene with grass and trees. the output format has an aspect ratio of 20:1 (if broken into parts at least 7:1) i need a very wide panorama without any wide angle lens distortions. when i set up a single wide angle camera that gives me a nice depth the foreground becomes way too distorted towards the edges. so i just want the perspective distortion along the z axis. so the scene has depth. wide angle lens around 22mm looks best. but i dont want the distortion along the x axis. rather something like using a frontal camera. cant get my head around on how to do that. things i dont want to do: stitching in post. using a front camera with faked depth by scaling objects. using a bent mirror i failed. any ideas? thanks Link to comment Share on other sites More sharing options...
cg_Butler Posted May 20, 2013 Share Posted May 20, 2013 Welcome. What software are you using? Link to comment Share on other sites More sharing options...
marcinleita Posted May 20, 2013 Author Share Posted May 20, 2013 i tried in c4d r13 and vrayforc4d. but if theres a solution in say max i'd love to know. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 20, 2013 Share Posted May 20, 2013 If you where a photographer, your solution would be tilt shift lens, and Cinema 4D and most of the 3d software have this options without the distance limits. Just set your camera around the middle of your objective, then adjust the lens size and take a snap shot, then increase your tilt distance from side to side taking different shots until you cover all your objective, then merge all the images in Photoshop. Of course this method have some limits but so it does real life photography, and our eyes can notice when we see something that does not look "normal" or our of the ordinary, if your shot it wide out or range, you better render a orthogonal elevation, but that is how it will look; right? Link to comment Share on other sites More sharing options...
marcinleita Posted May 22, 2013 Author Share Posted May 22, 2013 thanks francisco, but the lens shift doesnt help me as it just pulls the distorted edges of my frame into the center. i hoped i could make it work with a cylindrical camera but no. Link to comment Share on other sites More sharing options...
notamondayfan Posted May 22, 2013 Share Posted May 22, 2013 Do you have any reference images of the kind of thing you are trying to create? I might help us understand what you want and how it would be possible. Dean Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 22, 2013 Share Posted May 22, 2013 (edited) Yes I also think you need to post a sample of what your are trying to archive, because I have done something similar with a real camera and a tilt shift lens, not that exaggerated like yours 20:1 that's a lot. but in the 3d world i am sure it can be done. it should work, playing with lens size and film offset will give you a very wide shot without much distortion. Edited May 22, 2013 by fco3d Link to comment Share on other sites More sharing options...
