Noise Posted May 20, 2013 Share Posted May 20, 2013 Hi I have this problem occasionally and it is a pain - the attached image shows the same image in Photoshop (right) and also using the Windows Image Viewer (left). The windows viewer is alot darker and I cannot figure out why, does anyone have any idea's. Thanks N Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 20, 2013 Share Posted May 20, 2013 Check your color profile inside Photoshop. I have sRGB IEC61966-2.1 seems to work fine Link to comment Share on other sites More sharing options...
Noise Posted May 21, 2013 Author Share Posted May 21, 2013 That's what I have it set as - what does yours say for the Settings ? Mine is North America General Purpose 2 Link to comment Share on other sites More sharing options...
christofferthulin Posted May 21, 2013 Share Posted May 21, 2013 Check your color management in windows control panel. Maybe there is some funky business going on there. Windows viewer seems to be off sometimes, though the problem I once had did not concern the brightness. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 21, 2013 Share Posted May 21, 2013 That's what I have it set as - what does yours say for the Settings ? Mine is North America General Purpose 2 yes that's correct, as Christoffer mentioned check your windows profile, it should be the same, now some video card drives manage the color by application, so take a look at that too. Fco. Link to comment Share on other sites More sharing options...
Noise Posted May 22, 2013 Author Share Posted May 22, 2013 I did all the above and it has helped but there is still a noticeable tonal difference - Windows Viewer is still slightly darker. Link to comment Share on other sites More sharing options...
Noise Posted May 22, 2013 Author Share Posted May 22, 2013 (edited) The image in the first post was before calibration, the image below is after calibration and how it should look. What a difference. The very very strange thing is that it is only this image that is affected by the problem to this extent. Edited May 22, 2013 by Noise Link to comment Share on other sites More sharing options...
Fooch Posted May 26, 2013 Share Posted May 26, 2013 i had that issue too. Picasa and photoshop ran it well. windows viewer was clamping the blacks on the image. irritating because the client keeps seeing the crushed versions.. Link to comment Share on other sites More sharing options...
Noise Posted May 28, 2013 Author Share Posted May 28, 2013 Hi Fooch Did you manage to figure it out ? Link to comment Share on other sites More sharing options...
Fooch Posted May 29, 2013 Share Posted May 29, 2013 hi neil. no idea.. cant be arsed. installed picasa and showed via it. If clients complained later ill blame their monitors for it logically it should print well though because the range is in there Link to comment Share on other sites More sharing options...
