kishore3d Posted May 22, 2013 Share Posted May 22, 2013 How can i render Distributed rendering if Gi is disable (3s max Vray ) as im able to successfully connect to other Pc if Gi is enabled but, i want the render to be working fine without Global Illumination Enabled ' Please kindly some one help me Link to comment Share on other sites More sharing options...
Devin Johnston Posted May 22, 2013 Share Posted May 22, 2013 It shouldn't make any difference whether GI is enabled or disabled, distributed rendering is not dependent on it. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted May 22, 2013 Share Posted May 22, 2013 Do you get any errors? What does the Vray box tell you? How long does the render take? It could be that by the time you transfer your scene on the network to the DR box, your main box already renders it thus rendering (pun totally intended) the need for DR obsolete. DR is not dependent on having GI enabled as Devin points out. Link to comment Share on other sites More sharing options...
