Installing Vray for multiple versions of 3ds Max
cg_Butler
Hi all.
Is it possible to install Vray for multiple versions of 3dsmax? When I run the Vray installer, it says a version is already installed and needs to be deleted. I did a test and ok that, but now vray only works for max 2014 and not 2013.
Is it possible to have it installed for both?
  • Like 1
  • Sad 1
Are you trying to use Max 2013 and 2014 at the same time? I think until Chaos Group release a version of Vray for 2014, you'll probably just have to have one or the other, as I presume you're using the vray 2013 install, but manually changing the directory?
Once vray release it for 2014, you can have vray on both versions of Max.
  • 2 months later...
Hey Dean.
If you didn't know, there are seperate installers now for the latest build of VRay for 2013 and 2014. So I assume they can both be installed together now. (If you ever wanted to dip back in to a 2013 file and render it) :0
