seismograph Posted October 7, 2004 Share Posted October 7, 2004 convert your lightscape material libraries to architectural material libraries! just run it and point to your atr file. http://www.cgtechniques.com/goodies/ls_mat_converter.php Link to comment Share on other sites More sharing options...
Juan Altieri Posted October 7, 2004 Share Posted October 7, 2004 thanks, i will try it....... Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 7, 2004 Share Posted October 7, 2004 convert your lightscape material libraries to architectural material libraries! That would be nce, if I used MAX. Does this convert the great Lightscape glass to an as-good glass in MAX? Does it somehow transfer the specular, falloff, IR, etc? If so, can you post, in text, hoe those channels transfer? That could help in getting good glass in other renderers, like C4D. Link to comment Share on other sites More sharing options...
seismograph Posted October 7, 2004 Author Share Posted October 7, 2004 sorry Ernest, but it only copy the parameters to the so called architectural material, which seems to be a implementation of the ls material. This material uses the same shader but is slower (at least for me) Link to comment Share on other sites More sharing options...
molson Posted October 8, 2004 Share Posted October 8, 2004 Hi seismograph, Thanks for creating this script. I cannot get it to run correctly yet. I get an error, "No ""*"" function for undefined" I get the following in the maxScript Listener: "convert .Default Attr" " Flags: 0x1" " K_dr: -1" " K_dt: -1" " Texture Scale: 1" "no texture" "convert W02 Washed Maple" " Flags: 0x2040" " K_dr: -1" " K_dt: -1" " Texture Scale: 0.7244359850883484" "convert ate Name: Wood Varnished" "" -- Error occurred during fileIn in >> MAXScript FileIn Exception: -- No ""*"" function for undefined attached is the atr file I tried to open Thanks, Mark Link to comment Share on other sites More sharing options...
seismograph Posted October 8, 2004 Author Share Posted October 8, 2004 mark, just download it from the page again... it should work now. let me know! Link to comment Share on other sites More sharing options...
molson Posted October 8, 2004 Share Posted October 8, 2004 Excellent. works good now thanks Link to comment Share on other sites More sharing options...
