danb4026 Posted May 31, 2013 Share Posted May 31, 2013 Has anyone seen this issue before? You can see the diagonal line from the top left corner of the light fixture going to the bottom right corner. I have 3 shades in this scene using the vray2sided material and each is displaying the same problem. I have tried a variety of mapping methods and even smoothing groups to see if that could have anything to do with it, to no avail. Any insights? Link to comment Share on other sites More sharing options...
abhaysingh Posted May 31, 2013 Share Posted May 31, 2013 Hey Daniel, Is your geometry clean ?I think something is wrong with the geometry.You can check or you can send this object to me(Iam curious person ) though it's a simple box geometry with chamfer which you can model right away.Let me know. Link to comment Share on other sites More sharing options...
salvador Posted May 31, 2013 Share Posted May 31, 2013 Turn to EPoly - vertex mode - Crtl+A - Weld (use a very small threshold) Polygon mode - Ctrl +A - Retriangulate I agree, looks like turned edges overlapping faces. Same thing with any translucent material? Link to comment Share on other sites More sharing options...
