thiyagu Posted June 5, 2013 Share Posted June 5, 2013 i am using 3dsmax vray render,when rendering going raytrace massage come,how to identify that raytrace object with whole scene.how to remove. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted June 5, 2013 Share Posted June 5, 2013 The raytrace message is not necessarily a material. If you set your render engine back to default scanline and flip to the raytracer tab there is a tick box that says "Show Message". Untick this and the message should disappear. I don't know why this happens from time to time or why it shows up in Vray render scenarios. If it is a material, I'd check for a script on scriptspot.com Link to comment Share on other sites More sharing options...
abhaysingh Posted June 6, 2013 Share Posted June 6, 2013 You can convert all of your scene materials into vray by using "vray scene converter" command.That would solve your problem. Link to comment Share on other sites More sharing options...
cg_Butler Posted June 6, 2013 Share Posted June 6, 2013 To do what Abhay said you right click in your viewport and choose V-Ray Scene Converter Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted June 6, 2013 Share Posted June 6, 2013 Raytrace is also a MAP and the VRay scene converter only changes the material to VRay and would maintain the Raytrace MAP. I would try the converter, but I wouldn't rely on it being the solution. Link to comment Share on other sites More sharing options...
abhaysingh Posted June 8, 2013 Share Posted June 8, 2013 Scene converter removes the raytrace map. Link to comment Share on other sites More sharing options...
thiyagu Posted June 10, 2013 Author Share Posted June 10, 2013 thanks friends raytrace removing successful Link to comment Share on other sites More sharing options...
