michaelordway Posted June 6, 2013 Share Posted June 6, 2013 I recently printed a 48" x 24" image for a client at 150ppi. The size of the image was 7200x3600. The quality was beautiful, no problems. He's now requested it to be blown up even larger. He wants a 16 foot by 8 foot image (4.8m x 2.4m). I don't think re-rendering at 28800x14400 is the best way of doing this. What sizes and what ppi can I get away with while still preserving image quality? The image is going to go in a store window, so it has to remain fairly high quality from a few feet away. Michael Link to comment Share on other sites More sharing options...
M V Posted June 6, 2013 Share Posted June 6, 2013 This has been discussed quite a bit on these forums. Almost beaten to death really. Try a quick forum search. The thing to consider is that the viewing distance on a billboard will be much greater than someone standing 2 feet from a printed board. If you climb up to one of those highway signs, you would see that its very low dpi. I think I have heard 18-30 dpi for billboards, so your render at 7200 should be fine. Link to comment Share on other sites More sharing options...
michaelordway Posted June 6, 2013 Author Share Posted June 6, 2013 You are absolutely right. I did a search in the main search window on the site's homepage, not on the forum search! Thanks for the answer though! Link to comment Share on other sites More sharing options...
Stephen Thomas Posted June 7, 2013 Share Posted June 7, 2013 As a side note, those 3d people aren't going to look too pretty at billboard size. Might be worth thinking about replacing with photoreal people? Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted June 7, 2013 Share Posted June 7, 2013 It is all down to viewing distance. My 27" 1440p screen is only 114ppi, but viewing it @ 24" (60cm) or more looks immaculate. The natural viewing distance to fit the whole frame in our field of view is roughly the diagonal of the image. That would be nearly 18’ (17’-10" 5.43m) or for your 16’ x 8’. At this range, I think your current resolution will do ok...if they are to see it really close, I would perhaps double it...but don't try to get insanely precise. I don’t know what kind of bleeding the 8’ wide capable printer will have also, how smooth the material will be etc…having a 150ppi source file for an output that cannot exceed – say – 100 true dpi, is a waste. Link to comment Share on other sites More sharing options...
michaelordway Posted June 8, 2013 Author Share Posted June 8, 2013 The viewing distance is usually the diagonal. That's a good measure to keep in mind. Thanks for all the advice. I'm going to try printing at that size using the existing file as a test first. If it's good then I'll use that. Link to comment Share on other sites More sharing options...
