mbr Posted October 7, 2004 Share Posted October 7, 2004 I've got one file that I am trying to merge 5 others into. 3 work, the maps show in the viewport and render properly, but the other two only show the maps in the viewport, and when I render, they show up with a dark gray material where the maps should be. These files render properly before the merge and I am sure that the path is there for the bitmaps. Any ideas? There are far too many maps to reapply. Thanks. Link to comment Share on other sites More sharing options...
quizzy Posted October 8, 2004 Share Posted October 8, 2004 It could be a memory problem. Too many bitmaps? What you could try is to Resource Collect the files first to one directory, and merge them from there. Link to comment Share on other sites More sharing options...
nisus Posted October 8, 2004 Share Posted October 8, 2004 Do you use xrefs? if so, open the xrefs and do a resource collect from them too... rgds nisus Link to comment Share on other sites More sharing options...
