vanapapi Posted June 12, 2013 Share Posted June 12, 2013 (edited) Whenever I insert background to a viewport with windows explorer, it looks normal, but when I render, I get extremely zoomed in background image. What could be the cause of that? (I tried to fix it by resetting all the settings to default - deleted the 3dsmax.ini file. Didn't work) Images illustrating the problem are included in the attachments. Edited June 12, 2013 by vanapapi Link to comment Share on other sites More sharing options...
dhammikaherath Posted June 12, 2013 Share Posted June 12, 2013 Apply the same image to your environment background. Drag and drop it to a material slot as an instance. Then you can adjust it through material editor easily. Make viewport background to use the environment image. Link to comment Share on other sites More sharing options...
deC9r Posted June 12, 2013 Share Posted June 12, 2013 i think you checked the "affect backround" , turn it off, or get and alpha channel and reapply the brackround in psd Link to comment Share on other sites More sharing options...
vanapapi Posted June 12, 2013 Author Share Posted June 12, 2013 Apply the same image to your environment background. Drag and drop it to a material slot as an instance. Then you can adjust it through material editor easily. Make viewport background to use the environment image. Thank you! Got it fixed. For googlers, here is a video tutorial for background: Link to comment Share on other sites More sharing options...
John Dollus Posted June 13, 2013 Share Posted June 13, 2013 in the material editor, make sure you have screen mapping selected instead of spherical or cylindrical and that your tiling is set to 1 and 1. Link to comment Share on other sites More sharing options...
