acjwalker Posted June 12, 2013 Share Posted June 12, 2013 Hi people, I am having a few problems with scripts and basically I want to know where I can find them when they are installed. For example I am trying to see where the Center Gizmo script is installed to. There must be a folder somewhere. I am using 2013. I have tried searching in script folders and can see where some go (relinkbitmaps) Any Help? Cheers Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted June 12, 2013 Share Posted June 12, 2013 You can always drag and drop a file into the viewport and it will launch on its own. If it is the more involved type, you would run it and then you will see it in your Customize UI panel. If you want that available at all times you need to create a new button and put the script launcher there, then dock it to the ribbon. I know this is a little vague, but the process is lengthy to explain. I'm hoping the gist is enough to stumble through. Link to comment Share on other sites More sharing options...
acjwalker Posted June 12, 2013 Author Share Posted June 12, 2013 Thank you Link to comment Share on other sites More sharing options...
notamondayfan Posted June 13, 2013 Share Posted June 13, 2013 When you run a script and it installs its self it usually ends up here C:\Users\USER\AppData\Local\Autodesk\3dsMaxDesign\2013 - 64bit\ENU\usermacros Dean Link to comment Share on other sites More sharing options...
