3dvizual Posted June 12, 2013 Share Posted June 12, 2013 Hi. I would like to create a sun study animation of a building. Anyone knows of a video tutorial for making such a animation.? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted June 12, 2013 Share Posted June 12, 2013 Use the max daylight system (which you can animate) and replace the mental ray sun with a vray sun. Link to comment Share on other sites More sharing options...
3dvizual Posted June 12, 2013 Author Share Posted June 12, 2013 ok tx. I will give it a try. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted June 14, 2013 Share Posted June 14, 2013 The good thing about the max daylight system is the easy way of getting a semi-correct sun path based on the approximate location you select. I would do as Chris suggests; set up the max daylight system, animate the time of day (auto key and change the values of the time settings), turn off the max sun, then create a vray sun and link it to the max sun so it moves correctly across the sky. Good luck! Link to comment Share on other sites More sharing options...
