roangutierrez Posted June 15, 2013 Share Posted June 15, 2013 Im rendering my scene and suddenly i noticed that some of its parts are rendered as black objects.. I have attached an image, you can see there that my railings/bamboo poles doesnt render well when its not isolated from the rest of the model parts.. Those poles are just cylinders converted to poly.. I tried putting normal modifiers to flip its normals, but still it renders as black.. Im just using a target direct light for the scene.. This cylinders has UVW map already, Everything renders well except for this parts.. Suggestions everyone? Thanks.. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 16, 2013 Share Posted June 16, 2013 check your asset tracker in 3dsMax, it will tell you if all your textures are loaded or there is some path missing. What you meant with the railing does not render well when is not isolated? did your merged the mesh or are you talking about viewport isolation mode? Link to comment Share on other sites More sharing options...
dhammikaherath Posted June 16, 2013 Share Posted June 16, 2013 Check whether “Force 2-Side” is off in your render settings.. If yes, ON it and see. Link to comment Share on other sites More sharing options...
