how would one create a waterwall?
scostumatu
Hi all
Was wondering if anyone could help me out here... ive googled around and found a couple of tuts regarding a waterwall but theyre not as realistic as I want them to be... below are a couple google images of what im referring to - does anyone have any pointers on how i could achieve this?
either this subtle water wall:
http://www.davidharber.com/images/water/wall.jpg
or this more intense water wall:
http://www.decorfortheoutdoors.com/image/content/wall_fountains/wall-water-fountain-large.jpg (
any help would be much appreciated.
Thanks
The first sample can be done with a mix of noise maps as bump in a water/glass type of material. you can add some particles system at the bottom with a heavy motion blur on them to create the effect of water drop flying out.
The second sample also could be a mix of noise as bump and particle system, you can put a high speed on the particle system so it create a heavy motion blur on them.
Thanks very much for the insight - will look into that further and post back
cheers
Thanks for helping out guys - will look into the above methods and post results..
cheers
I've done a waterwall in an animation and that's how I did it -- a bump map made of animated noise with a motion speed downward. I skipped the particle bottom, as there was no time or budget to get that fancy. The wall looked good, especially with sound.
