jamescondliffe Posted June 23, 2013 Share Posted June 23, 2013 Hi guys. I've been using Vray for about a month now, and slowly getting to grips with it. However I'm just wondering what the general consensus was when it come to Vray or IES lighting for interiors. Most tutorials I've gone through use Vray but a few have introduced me to IES. I've found tho that using IES A: slows down my renders and B: takes longer to tweak to get a good result. I was just wondering what the professionals used on a daily basis. Is the speed of using Vray lights overall better than going for the IES option? Cheers in advance for the help. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 17, 2013 Share Posted July 17, 2013 Use VRayIES Lights Good luck dude Link to comment Share on other sites More sharing options...
RyderSK Posted July 17, 2013 Share Posted July 17, 2013 The Vray version is just simplier to setup as there is literally nothing to tweak, which is just fine in "most" cases. One exception to this would be the softness of shadows, which you would have to correct then in the .ies file itself using text editor (it's though very simple operation). I never use the regular IES photometric because it's the exact opposite, over-bloated settings with many potato values, and I don't have nerves nor time to deal with that. Link to comment Share on other sites More sharing options...
notamondayfan Posted July 18, 2013 Share Posted July 18, 2013 Vray lights, and spot lights for me. It really depends on what you are trying to achieve. Link to comment Share on other sites More sharing options...
Vince Paske Posted July 18, 2013 Share Posted July 18, 2013 Use both. I use IES lights when there's a need to produce an accurate "shape" of the light source. Also - your system units needs to match the IES to be accurate. Link to comment Share on other sites More sharing options...
