ipdesigner Posted October 9, 2004 Share Posted October 9, 2004 *anybody help me in setting-up the 'volume light' under atmospheres & effects. *i have here attached image, also taken from this site...the same thing what i want to achieve.. *software: 3DS Max v.5, im using radiosity. *thnx! Link to comment Share on other sites More sharing options...
skogskalle Posted October 9, 2004 Share Posted October 9, 2004 not really sure what you want help with? I cant give you any special settings and stuff, cause I think this differs from scene to scene... The tip I can give you is that you must use a light that has shadow maps as shadows. I dont work with raytraced shadows, atleast not in 3dsmax4 which I use... Not sure about this, but I belive you get more detailed volyme light if you increase the size of the shadow map. I think all you have to do is open the render/effects menu, select "volume light" and then select the lightsource you want to appy it to, then adjust the density of the fog... this is pretty much trial and error.... start with a low value and go from there... havent used this effect in a long time, so dont hate me if Im wrong =) hope it helps! Link to comment Share on other sites More sharing options...
Dust to Dust Posted October 10, 2004 Share Posted October 10, 2004 sharp volume light & it's edges may have some glow Link to comment Share on other sites More sharing options...
ipdesigner Posted October 10, 2004 Author Share Posted October 10, 2004 skogskalle said: not really sure what you want help with? I cant give you any special settings and stuff, cause I think this differs from scene to scene... The tip I can give you is that you must use a light that has shadow maps as shadows. I dont work with raytraced shadows, atleast not in 3dsmax4 which I use... Not sure about this, but I belive you get more detailed volyme light if you increase the size of the shadow map. I think all you have to do is open the render/effects menu, select "volume light" and then select the lightsource you want to appy it to, then adjust the density of the fog... this is pretty much trial and error.... start with a low value and go from there... havent used this effect in a long time, so dont hate me if Im wrong =) hope it helps! *thnx skogskalle..still cnt even get it right , btw..one friend told me that it's really heavy for rendering time...ill crack the bone later! Link to comment Share on other sites More sharing options...
skogskalle Posted October 10, 2004 Share Posted October 10, 2004 hey again... forgot one thing.... Since it uses the same technique as a shadowmap, it cant go through glass, no matter how low the opacity is. so, to make it shine through a window you must exclude the glass... and yes, I think it can take a while to render.... Link to comment Share on other sites More sharing options...
pixelperfectg Posted October 10, 2004 Share Posted October 10, 2004 Why not just add it in post with something like photoshop? It would obviously be quicker than rendering it, and you would probably have more control over the look of the rays. Jeff Link to comment Share on other sites More sharing options...
ipdesigner Posted October 10, 2004 Author Share Posted October 10, 2004 pixelperfectg said: Why not just add it in post with something like photoshop? It would obviously be quicker than rendering it, and you would probably have more control over the look of the rays. Jeff *yeah, it will do and i tried it already , only i just want to do it in max..btw, thnx! Link to comment Share on other sites More sharing options...
