Instances or one mesh?
rashed
Hello everybody I am working on a big scene (theme park) and there is around 140 street lamp model in the park, my question is which is better for scene and RAM management: to attach them all as one Edit Poly or keep each one separate with them being instanced ofcourse?
Thanks
Good question!
I would always go with instances rather than attaching them all together. Just in case you need to change the model. You can also save them out and XREF them in so your scene runs smoothly, or turn their visibility in to a bounding box.
If you use VRay or Mental ray create a proxy from one on the lamps and then instance that proxy, that's the best way by far.
