error at the end of rendering
dreamdeam
hi, i'm rendering a scene, at the end of each render a window appears containing a path that doesn't exist in my lap top
if i click retry, nothing happens
if i click cancel, there will appear at the bottom of the picture unwanted grey ribbon as shown in the screenshot
how to deal with this window?
Check to make sure you aren't using "Save as" in your common render settings. Since it is an I/O error at the end of the render, that suggests Max is trying to save your render to a place that doesn't exist.
The dialog is from Vray. You can turn it off in the Vray render settings under the "Settings" tab and uncheck "Framestamp"
I think you've answered your own question by saying the output path doesn't exist on your laptop. It's trying to save that element to that location and it cant because it doesn't exist. Does it work if you create that location and re-render?
