Zdravko Barisic Posted July 10, 2013 Share Posted July 10, 2013 I have to make something like this Uploaded with ImageShack.com With standard geosphere, and shere, I did not make more than this Uploaded with ImageShack.com The Goal is: How to make that horizontal lines STAY horizontal, as on the first image??? Thanks!!! Link to comment Share on other sites More sharing options...
cg_Butler Posted July 10, 2013 Share Posted July 10, 2013 (edited) Easy. Use a geosphere. Add an edit Poly and in a front or side viewport select the vertices along one of the wonky edges and scale it in the y axis. HERE is an example maxfile saved in 2012. If you need an earlier version let me know. Edited July 10, 2013 by cg_Butler Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 10, 2013 Author Share Posted July 10, 2013 Thank you Andy! I already tried that, but what you get is disturbed mash, for some more precise work. Look at this, please, as you can see, from the top it is somehow penthagon! Also, from the front view there are some small deformation. Perhaps, for the 4 segments it is almost OK, but for 5, I am not so shore. Uploaded with ImageShack.com Link to comment Share on other sites More sharing options...
cg_Butler Posted July 10, 2013 Share Posted July 10, 2013 Yes I noticed it distorted in a few places but thought it might be acceptable. Have you tried arraying? Perhaps draw a triangle to start with and place it's pivot point as if it was the center of the sphere (You could dray another geosphere that the right size and align the triangles pivot to it.. You'd get precise results if you know the exact scale. Then do a 3D array and see what happens! Do you know what happens on the top of that building. Can you see it on google earth? That might help. Or obtain more references of it. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 10, 2013 Author Share Posted July 10, 2013 I think I will go 4 segments, it is reasonable, also with very little small mistakes I do not where is the building Link to comment Share on other sites More sharing options...
cg_Butler Posted July 10, 2013 Share Posted July 10, 2013 Fair enough. Tricky thing to model using generic objects. Like I said if you know the dimensions of the triangles and how many there are in the framework an array would work really well I think. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 10, 2013 Author Share Posted July 10, 2013 Hey Andy, please look at the top of the existing building, you see that the mesh is already changed! So, this is more mathemathic problem!!! :) Link to comment Share on other sites More sharing options...
cg_Butler Posted July 10, 2013 Share Posted July 10, 2013 I had noticed that but didn't want to complicate things for you! Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 10, 2013 Author Share Posted July 10, 2013 http://69.32.146.131:8090/celt/267/media/images/content/F021_030.jpg Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted July 10, 2013 Share Posted July 10, 2013 Use a regular old Sphere. Place an Edit Poly modifier on it. Select all faces and in the Graphite Modelling Tools there is a Generate Topology menu under Polygon Modelling. Choose Diagrid. The Sphere is now made from Diagonal Quads. If you then use a Front View and select the Verticies in horizontal groups (one row at a time) you can hit Connect and get your straight horizontals with triangular faces. Experiment with lower segments, but it should work. Link to comment Share on other sites More sharing options...
cg_Butler Posted July 10, 2013 Share Posted July 10, 2013 I was messing around with that method too myself, thinking i had struck gold and then saw your post! Well played sir! Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted July 10, 2013 Author Share Posted July 10, 2013 Man this SO pervert!!! THANK YOU!!! ... :) Link to comment Share on other sites More sharing options...
cg_Butler Posted July 10, 2013 Share Posted July 10, 2013 I think you meant perfect? Whoops! Link to comment Share on other sites More sharing options...
