Xeon E3 1230V3 Hasswell - Impressive with Vray renderer.
Hello everyone.
Recently, I have some quick test with Xeon E3 1230V3, a Hasswell base CPU with a famous 3D renderer : Vray
I used 2 version of 3dsmax & Vray to do my tests.
  1. Vray 1.5SP5 & 3dsmax 2011
  2. Vray 2.40.03 & 3dsmax 2012
The rendering time to finish the render tasks of Xeon E3 1230V3 are really impressive compare to the previous gen CPUs.
I did my tests with 2 3dsmax scenes from Evermotion.
(Lightcache/Number of passes is set to 8/12 to match the CPUs core/threads)
Archinteriors 01 - vol 01:
Archinteriors 03 vol 16:
My hardwares :
  1. Intel Xeon E3-1230V3 Haswell LGA 1150
  2. Crucial Single 16 chip 8GB ( 2x4GB ) bus 1600
  3. Gigabyte H87M-D3H - LGA 1150
  4. Western Digital Caviar Blue 1TB
  5. Sparkle NVIDIA GTX 650
  6. Corsair Builder VS450
  7. Zalman CNPS 5X Performa
  8. THOR Athena Mid-Tower Gaming Case
Edited by Superkames
The results:
All screenshots can be downloaded here : http://www.mediafire.com/download/v67qvbuh52ewqvq/Screenshot.rar
And the charts:
Archinteriors 01 - vol 01::
Rendering time (second): lower is better.
Archinteriors 03 vol 16::
Archinteriors 03 vol 16 - Rendering time (percent) compare with Xeon E3 1230V3:
I did not have seen a similar test before, but beating a Sandybridge EP arch (3820) by 30%, while rated @ 70% or less TDP, is simply amazing.
Looks impressive - almost too good to be true:
3820 has an "aggregate" GHz of 8 Threads * 3.6GHz = 28.8 GHz @ Sandy EP
The peppy Xeon has 8 Threads * 3.6GHz = 26.4 GHz @ Haswell
To beat the 3820 by 30%, that means the Haswell Xeon is nearly 42% more efficient in VRay over Sandy EP (Sandybridge Xeons).
The rest of the compute benches I've seen place it more in the 15-17% range, which is more believable and consistent, but I would be glad to be surprized.
Great presentation at any rate.
15-17% range is ok if you compare them with Cinebench R11.5 or scanline renderer.
Vray is a different story and it is rarely seen in CPUs reviews .
Cinema 4D R13 - default renderer is also different from Vray or Cinebench R11.5:
Try it yourself if possible and you will see how impressive it is.
interesting!
But if this is true it looks like it must be something v-ray related (and maybe c4d R13), because the maxwell scores look almost the same as ivy bridge. Maybe they are already using AVX2?
btw. the FX8350 looks impressive too here!
