danb4026 Posted July 12, 2013 Share Posted July 12, 2013 This really annoying and just started happening. When ever I enter sub object mode in an edit poly, the object I am working on disappears. Anyone encounter this problem? Link to comment Share on other sites More sharing options...
notamondayfan Posted July 12, 2013 Share Posted July 12, 2013 It happens with splines, to solve this untick back-face cull in the object properties, perhaps it'll work on edit meshes? Link to comment Share on other sites More sharing options...
Casey Hawley Posted August 30, 2013 Share Posted August 30, 2013 This happens to me sometimes in Max 2013. Without even noticing it sometimes, so later I suddenly realize that a mesh is just gone. But I've learned that it's just not showing, that it's still there. Often it will reappear once I put a modifier on it, like a Turbosmooth, or UVW Map, etc., or if I make significant changes, like deleting faces, or extruding edges. The back face cull thing didn't do anything as it is always unticked for me. I am using dual Quadro 4000s with latest drivers. Link to comment Share on other sites More sharing options...
danb4026 Posted August 30, 2013 Author Share Posted August 30, 2013 This is exactly what happens to me. I have not been able to find a resolution. Link to comment Share on other sites More sharing options...
bwill71 Posted January 25, 2014 Share Posted January 25, 2014 3ds Max 2014 all patched up to Service Pack 3 and this sill occurs. Has anyone really found a true fix for this. Back-face cull suggestion didn't work, was already un-ticked. I have a simple spline with an arc that I need to 'Refine' but when in Segment mode the spline disappears. Link to comment Share on other sites More sharing options...
RyderSK Posted January 26, 2014 Share Posted January 26, 2014 Try selecting something, like vertice, etc.. anything that you're inside with in sub-selection. It's still there....just invisible. I am annoyed by this bug too. Link to comment Share on other sites More sharing options...
jimperry Posted March 28, 2014 Share Posted March 28, 2014 I'm having the same issue, with Edit Mesh and Edit Poly on a Mesh I'm trying to mess with, and I ended up switching my viewport render driver to a legacy DirectX 9 driver from the "recommended" DirectX 11 driver, and that seemed to work. Now when I click Edit mesh and go into the sub-object mode, my model doesn't disappear. Link to comment Share on other sites More sharing options...
Jason L Posted January 17, 2024 Share Posted January 17, 2024 Sorry for the thread necromancy! I just found this thread when trying to find a fix for this issue. It began for me when Autodesk introduce the Nitrous display driver, and has plagued all versions of 3DSMax I have tried. The problem is that when you isolate an object and go into sub-object mode the mesh disappears. If you drag a window over the mesh the vertices appear, but as soon as they are deselected they become invisible again. I have always used Nvidia consumer level cards with 3DSMax. Is this an Nvidia driver problem? Link to comment Share on other sites More sharing options...
