How would you model this?
shauncarollo
http://i.ebayimg.com/t/Hand-Twisted-Glass-Pendant-By-Prospetto-Flamingo-Modern-Look-Very-Unique-/00/s/MTYwMFgxMjAw/$(KGrHqF,!ocE9eGelY)JBPm(riUunw~~60_35.JPG
I've got to model this for the project I am working. I started with a cylinder with 48 height segs, 32 width segs. Added taper, and then tried a bend modifier but I cant get the tubes to come out right. I'm hoping that I don't have to do it with a spline/offset.
Any suggestions?
Thanks for the replies guys. I ended up creating a spline and just lofting a circle around and adjusting the taper and curve--so thanks :)
I've got another modeling question (hopefully the last; I'm nearly completed with this project) How would you model this textured wall by Interlam? It's one of those milled MDF architectural panels.
http://interlam-design.com/wp-content/gallery/facets-ii/facets-ii-elements-sculpted-wall-panel-002.jpg
I'm sorry if this is elementary--I've only been working in max for under a year. I tried to create a plane with all different kinds of tessellations and grid patters, even random quick slicing to get the randomness and then adjusting with a noise modifier but I cannot seem to get it right. This wall is 10' tall and spans our entire office--80' or so, going from room to room with really nice grazing light. What do you think is my best bet for getting it accurate?
Create your plane that is the basis of the wall. Add a subdivide modifier so that you can control the size of your tessellation. Add a noise, turn on fractal and change the roughness to 1.0. Set the strength to get the offset. Lastly, I would add an edit poly and select all faces and clear the smoothing groups. I would also select the border and make it planar so that you have a flat edge. If you want it UVW mapped, I would put that modifier before the noise and I think that's about it.
Edit: You'll likely want to model some after the noise... maybe chamfer selected verts, but i think this will get you started for sure.
Edited by CoreyMBeaulieu
Keep in mind I haven't developed a final lighting solution for this area yet. I'm using a Vray plane light, temp 4000, intensity = 10 default (image) units. Why does this look so bad? Should I be using a different kind of Vray light to get a wall wash effect with more distributed attenuation?
  CoreyMBeaulieu said:
You need to clear the smoothing so that the noise is hard edges not smoothed over.
You can accent it, too, by using an edge texture in the diffuse
You mean go into polygon sub-selection, then clear all in smoothing groups? because that's done.
