jackdicker Posted July 30, 2013 Share Posted July 30, 2013 I in extreme need of a chamfer plugin for sketchup.. can anyone help? Something that will round off or smooth off my sharp corners? Thanks! Jack Link to comment Share on other sites More sharing options...
numerobis Posted July 30, 2013 Share Posted July 30, 2013 http://sketchucation.com/forums/viewtopic.php?f=323&t=20485 hard to find?!? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted July 30, 2013 Share Posted July 30, 2013 There's a new website called google that is gaining a lot of popularity at the moment when it comes to searching for things. You might like to try it, it can turn up all kinds of useful information that you would otherwise have had to ask for on forums, thus resulting in you having to wait for replies and resulting in other people to go out of their way to find the information for you. It will probably save you some time. Check it out at http://www.google.com If you still need a helping hand, try this link; http://www.lmgtfy.com/?q=sketchup+chamfer+corner+plugin Link to comment Share on other sites More sharing options...
jackdicker Posted July 30, 2013 Author Share Posted July 30, 2013 wow I'm pleased i decided to join this forum a couple days ago.. its very friendly (not).. sorry I wasted your time guys i was just curious about what site offered the best plugins and hadn't ever made a post before so thought i would test the water and say hello, trying to be friendly and all. thanks again for the comfort. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted July 30, 2013 Share Posted July 30, 2013 The problem is that this site is (almost daily) flooded with questions that could simply be resolved by a quick google search. It waters down the amount of useful information available here to everyone with questions like "how I set up vray lighting?" or "daylight tutorial plz". Just a modicum of common sense needs to prevail is all. Welcome aboard, it really is a very friendly place actually, sorry to have given you such a hard time. Link to comment Share on other sites More sharing options...
numerobis Posted July 30, 2013 Share Posted July 30, 2013 sketchucation is all you need for sketchup. the plugin section lists almost every available plugin and there is a plugin called "SketchUcationTools" which lets you search and install plugins from within sketchup. http://sketchucation.com/forums/viewtopic.php?f=323&t=28782 http://sketchucation.com/forums/viewtopic.php?f=323&t=51728 I think some must have free plugins are: - FredoTools - FredoScale - RoundCorner - Mirror - Joint Push Pull - Curvizard - Curviloft - BezierSpline - Selection Toys - CleanUp³ - Edge Tools² - QuadFace Tools - UV Toolkit² - Material Tools - Tools on Surface - Architect Tools - Extrude Tools - 2DTools You can also search the new Extension Warehouse, but i think they don't have all plugins listed at the moment. http://extensions.sketchup.com/ Link to comment Share on other sites More sharing options...
jackdicker Posted July 30, 2013 Author Share Posted July 30, 2013 Thank you so much guys sorry we got off on the wrong foot. I think I need to install that as a start to allow me to install those plugins. Thats what confused me so thanks. I have another question.. Im trying to create a 3d floor plan render with the building cut at about 1.5m high. Now when I render the scene is there a way for it to stop snapping back to the full building? Im only wanting to render my plans where I have created my cut? Hope that makes sense! Link to comment Share on other sites More sharing options...
numerobis Posted July 30, 2013 Share Posted July 30, 2013 you can install all plugins manually simply by copying the files and folders into your sketchup plugin folder! (if they are no commercial plugins with an installer) This sketchucationtools plugin is only a way to automate the install and give you a search engine. I haven't tested it myself for now, but i'm still installing all plugins manually, so i can't say how good it works. But i think it should be ok. The automated installation from the Trimble extension warehouse is only supported by the awful SU 2013 as far as i know. Link to comment Share on other sites More sharing options...
numerobis Posted July 30, 2013 Share Posted July 30, 2013 T Im trying to create a 3d floor plan render with the building cut at about 1.5m high. Now when I render the scene is there a way for it to stop snapping back to the full building? Im only wanting to render my plans where I have created my cut? Hope that makes sense! this is a function that has to be supported by your render engine. Otherwise you have to cut it manually (there are also plugins to do this) or hide the faces. Link to comment Share on other sites More sharing options...
jackdicker Posted July 30, 2013 Author Share Posted July 30, 2013 thanks guys, I have figured it out, pretty straight forward, i was just confused as which plug-in installer to go for. all done now. still need to figure out how to render a cut section but will have a play before I ask anymore q's Link to comment Share on other sites More sharing options...
M V Posted July 30, 2013 Share Posted July 30, 2013 Please post all SketchUp related posts in the SketchUp forum. Link to comment Share on other sites More sharing options...
