need help render an exterior scene in 3ds max 2011
sudheeshkrishna
hi,,,,
Im sudheeesh worked as a proffessional in architextural visualization..i nee da help in 3ds max 2011,,,
i have good system configuration --- i7 processor,16 gnb ram,,2 gb graphics card,1 tb hard disk(all are latest parts in the market)
but my system take 1 or 2 hour to render an exterior & Interior scenes,,,,,wt can i do to speed up my rendering time,,,,,
this is the rendered image and vray settings
this rendering takes 2 hour,,,,
rendering page size was A4 with 300 resolution,,,,,,plz give me the help to reduce the rendering time,,,,,,
and plz give me the basic settings of vray for exterior and interior,,,,
Edited by sudheeshkrishna
A4 @ 300 dpi = 3508 X 2480. That's pretty high resolution! 2 hours for such a big render is not that long, even though your scene is pretty simple. The water must be quite long to render.
Brute force, while very accurate is also very slow. Try using Light cache instead. That will speed your render a lot.
Dear Sudhee
Do these settings:-
Under V-ray Environment: Remove refraction override
Under Global settings: Remove Hidden lights
Under Color mapping: Remove clamp output
Under miscellaneous: Remove max compatible option
And, instead of Brute Force use Light Cache.
Hope these changes will lessen your rendering time a lot
  • 3 weeks later...
  • 4 weeks later...
