Randy liddil Posted August 6, 2013 Share Posted August 6, 2013 I have about 50 studio max scenes that are pretty small in size and only about 20mb each. I need to send them all to Backburner to render. Is there ANY way to send all of these scenes to Backburner through some kind of script or plugin? So I don't have to open up every single scene one at a time. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 6, 2013 Share Posted August 6, 2013 Don't quote me on this, but I doubt it. Scripts run within scenes, not outside of them? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 6, 2013 Share Posted August 6, 2013 Command line rendering; http://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-Help/index.html?url=files/GUID-07D3D0DD-3C22-4305-B7FA-01508AB73393.htm,topicNumber=d30e451772 If the link takes you to the batch rendering help, just click on the command line rendering link in the Note. Link to comment Share on other sites More sharing options...
Tommy L Posted August 6, 2013 Share Posted August 6, 2013 There may be some way import x-Ref according to scene state and then batch render? This isnt something Ive come across before, just an idea. If its a one off then maybe just open the files and render them. It will probably take the same amount of time as finding an automated solution. -or you could get an intern... Link to comment Share on other sites More sharing options...
notamondayfan Posted August 7, 2013 Share Posted August 7, 2013 You might be able to do a post-render script which changes an xref scene, and then renders again. Link to comment Share on other sites More sharing options...
