stayinwonderland Posted August 7, 2013 Share Posted August 7, 2013 I just get a solid grey colour. In one of the viewports the grey flashes on and off when I click it. Sounds like a big problem this one. I opened another, older scene which has HDR in it but that was ok. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 7, 2013 Share Posted August 7, 2013 This might be a stupid question, but have you remembered to adjust the settings, it might just be overexposed? In the vray hdri map loader, set it to a multiplier by 0.02 and then x50 (so that it is back to 1) by rendertime. If you have allready done this, i am not quite sure what the problem is, sorry. Link to comment Share on other sites More sharing options...
stayinwonderland Posted August 7, 2013 Author Share Posted August 7, 2013 Thanks. Nah, it's just grey. If it were white I could imagine this being the case. Link to comment Share on other sites More sharing options...
christofferthulin Posted August 8, 2013 Share Posted August 8, 2013 Yea I had this problem from time to time in different scenes. I don't know what causes this, all I know is that in Max 2014 I have never had this problem. Link to comment Share on other sites More sharing options...
cg_Butler Posted August 8, 2013 Share Posted August 8, 2013 I've thought of a few things.... What graphics driver are you using in max? Try switching between them. What is your graphics card and how much RAM does it have? How big is the HDRI you are trying to load in? Perhaps your graphics card cant display it because it runs our of RAM? Especially if you have other maps visible, and lights, occlusion etc. Try resizing the HDRI and saving as a jpeg and applying that in the background and see if it displays. Link to comment Share on other sites More sharing options...
stayinwonderland Posted August 8, 2013 Author Share Posted August 8, 2013 Hmmm, this doesn't make any sense because a) I've used this side HDR (indeed the exact same file) countless times before. And the fact that I can open another file and view it ok rules out that too. Plus it does show up in the render. Just have to live with it I guess. These things happen. I think software ages (not just the authoring tool but in collaboration with the operating system and plugins etc) Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 8, 2013 Share Posted August 8, 2013 Assuming you are using nitrous. Are you using show realistic materials in viewport (Views-Show Materials in Viewport as-) or are you showing them as shaded maps? Using the realistic materials option is like back in direct3d with the match bitmap as closely as possible so nitrous will take somewhere near forever in trying to show the actual full res HDR in the background. This setting is per file and not global. Link to comment Share on other sites More sharing options...
