mariosantana Posted August 9, 2013 Share Posted August 9, 2013 Does anyone know why this happens and how can it be avoided/fixed? if you see the pics there's something weird with render mesh. I checked the geometry and everything is where it is supposed to be. this is 3ds max 2013. first one is a rendered image, second is screen capture. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 9, 2013 Share Posted August 9, 2013 Try resetting your smoothing groups. Link to comment Share on other sites More sharing options...
Jose Negrete Posted August 9, 2013 Share Posted August 9, 2013 (edited) can you do another screen cap w/ edged faces on? It looks like the lower edge of the chamfer was target welded down *but there is still a vertex where the chamfer corner belongs (not sure if that makes sense) *edit: thats what it looked like to me. Edited August 9, 2013 by acad-gatsu Link to comment Share on other sites More sharing options...
mariosantana Posted August 9, 2013 Author Share Posted August 9, 2013 it was created using a profile curve and sweep command. here is the screen cap with edges on. Link to comment Share on other sites More sharing options...
mariosantana Posted August 9, 2013 Author Share Posted August 9, 2013 tried that and it did nothing. Link to comment Share on other sites More sharing options...
Jose Negrete Posted August 9, 2013 Share Posted August 9, 2013 Shouldnt you have 2 edges on the top tiers like seen on the lowest chamfer? Link to comment Share on other sites More sharing options...
mariosantana Posted August 9, 2013 Author Share Posted August 9, 2013 you're right. The strange thing is that row looks good everywhere else. how can i add an edge there? Link to comment Share on other sites More sharing options...
Jose Negrete Posted August 9, 2013 Share Posted August 9, 2013 (edited) just wondering if it may be caused by the profile curve. Maybe all the vertices are not coplanar. or if your corner chamfers/fillet have bezier curves and some of those handles are not coplanar? just guessing here. *in edit poly, you can connect vertices using the connect tool under edit vertices rollout Edited August 9, 2013 by acad-gatsu Link to comment Share on other sites More sharing options...
mariosantana Posted August 9, 2013 Author Share Posted August 9, 2013 that worked but it created a bunch of faces and distorted adjacent faces.this was created in rhino and imported as 3ds object. i think it may be easier to reimport it. thanks for all your help. Link to comment Share on other sites More sharing options...
Jose Negrete Posted August 9, 2013 Share Posted August 9, 2013 http://designreform.net/learning/2011/10/04/exporting-solids-rhino-3ds-max Link to comment Share on other sites More sharing options...
