alimarafia Posted August 10, 2013 Share Posted August 10, 2013 Hi, I've made a lot of trees using the instance command ( move/shift/instance ) however the file became more more slow to manipulate. I would like to know if it is possible to display the instances as bounding box or any simpler geometry. thanks in advance Link to comment Share on other sites More sharing options...
Krisztian Gulyas Posted August 10, 2013 Share Posted August 10, 2013 (edited) Select the trees, right click, object properties, general tab, display as box Though if you've created so many trees, the render-time will be veery long. Edited August 10, 2013 by krisztiangulyas Link to comment Share on other sites More sharing options...
alimarafia Posted August 11, 2013 Author Share Posted August 11, 2013 Thanks krisztian. Though if you've created so many trees, the render-time will be veery long. Indeed it is. As a newbie in this area, I would be interested to know if there is a better way to copy trees without this render time-issue. Link to comment Share on other sites More sharing options...
Krisztian Gulyas Posted August 11, 2013 Share Posted August 11, 2013 You're welcome. You can use proxies. If you're using VRay, then right click, vray mesh export, give that object a name, tick "atomatically create proxies", set "faces in preview" to about 5-15 thousand (5-15 percent of the faces the original object has), and you can copy them. It's faster (shorter render-time) than copying them as instances, but it always takes a lot of time to render realistic trees. Link to comment Share on other sites More sharing options...
Jose Negrete Posted August 12, 2013 Share Posted August 12, 2013 you might also have the tree proxies in their own file and xref them in when needed. Link to comment Share on other sites More sharing options...
