Guest eddie57 Posted October 12, 2004 Share Posted October 12, 2004 All of a sudden some of my drop down menus are gone. some of the missing menusfor example are the Desktop menu and the Help menu. I typed "menu" at the command line and loaded the various menus there, but none added the missing menus. I reinstalled ADT and they came back. On the next day I tried using the program again and the menus were gone again. Any suggestions on how to get them back without reinstalling adt? It's version 2. I know, it's not a good version. thanks in advance Eddie Link to comment Share on other sites More sharing options...
sky Posted October 14, 2004 Share Posted October 14, 2004 I had menu problems when I loaded both autocad and adt menu's together. I used the "menuload" command and was able to customize exactly what I wanted. Did you already try that? Link to comment Share on other sites More sharing options...
David Barbarash Posted October 14, 2004 Share Posted October 14, 2004 The problem could also be in your file path setup. Go to the options menu and then the files tab. Be sure that your menu's are being linked to the correct pathways either in your CAD install directory, your local profile (under documents & settings/application data/...), or a networked storage area. There should be entried in the menu section, as well as the file support path section too... Can't give too detailed help without knowing your exact computer setup and config, but it sounds to me like your CAD profile is getting corrupted and losing its links... Link to comment Share on other sites More sharing options...
