A method to test different sun angles?
jonasthomas
Hello,
I am working on a big project with lots of different buildings and I want to know what the best lighting situation is. It's a pretty important project and therefore I was wondering if someone knows about a method or a script I can use to make something like 100 different low-res renders with the sun coming from a different angle in each render?
If anyone has a solution or tips for this, I'll deeply appreciate it!
Thanks in advance,
Jonas
You should generally know where the sun will make the building look its best, so you probably aren't going to need to see too many variations, ie you very rarely want the sun either behind or in front of the camera.
I personally have never seen the need to create an automated way, to me it's just over-thinking the concept. Low and fast render settings, then hand position lights always works for me.
Dean
Thanks for the answers! An animation sounds like a good idea. I didn't think of that.
@Dean Purchard: I think you may be right. Placing the sun in front or behind the camera is probably not a good idea, but this is actualy a personal project, so there is more time and I would like to test every possibility. Maybe it's a bit fanatical, I know, but I still want to try it at least once. :-)
Thanks!
