spencerfitch Posted August 19, 2013 Share Posted August 19, 2013 Hey whats up guys. I have apparently ran into an issue that just baffles me. I had my vray camera setup, its been working fine for the last couple of days. Ive been able to render out as much as I want no issues and its been great! Well i close out of maya 2012, run some errands, come back and re load maya with the scene and when I do a test render it builds the photon maps and caustic maps but it renders out a black image. Nothing more. There is nothing in front of the camera and none of the camera attributes have been changed from when it was working. Does anyone have any insight to this? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 20, 2013 Share Posted August 20, 2013 I've had cameras corrupt before, just create a copy of it and try rendering from the new one. If it doesn't work still, it's probably not a camera issue (given that you haven't changed any of its settings). Link to comment Share on other sites More sharing options...
spencerfitch Posted August 20, 2013 Author Share Posted August 20, 2013 Macker said: I've had cameras corrupt before, just create a copy of it and try rendering from the new one. If it doesn't work still, it's probably not a camera issue (given that you haven't changed any of its settings). Same thing from the camera being duplicated. However if i create a new camera its fine as long as i input the same settings as the previous corrupted camera. Link to comment Share on other sites More sharing options...
notamondayfan Posted August 21, 2013 Share Posted August 21, 2013 You haven't ticked "don't render final image" by accident have you? Link to comment Share on other sites More sharing options...
spencerfitch Posted August 21, 2013 Author Share Posted August 21, 2013 notamondayfan said: You haven't ticked "don't render final image" by accident have you? Nope! One of the first things I checked. I just double and triple checked also. I have no clue what happened! Link to comment Share on other sites More sharing options...
