zanderadrian Posted August 25, 2013 Share Posted August 25, 2013 Hello, I could not find an answer to my problem so I will post my question here. When wanting to render more camera angles, is there a way to set different aspect ratios to each camera? I have some landscape type close-ups and some portrait far away shots and with one aspect ratio (set in the render settings) it is pretty hard to find the right framing. So...is there a way to set individual aspect ratios or do you have to adjust on each frame? Thank you. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 26, 2013 Share Posted August 26, 2013 You can set up batch render to render different aspect ratios. Link to comment Share on other sites More sharing options...
