aristocratic3d Posted August 27, 2013 Share Posted August 27, 2013 HI, Any heard about a script that allows to make the objects within the camera renderable. in another word I want to uncheck renderable option from object's object properties that are not within the camera. I know I can simply do that from object properties. but I have a automatic setup that will render multiple cameras. so I want each camera to render only what objects is there within this specific camera's range. Thanks in advance for help. Link to comment Share on other sites More sharing options...
H A Posted August 27, 2013 Share Posted August 27, 2013 Dunno about the script, but you can use the scene state manager in max (presuming you are working in max?) and render your cameras with scene states defined. Link to comment Share on other sites More sharing options...
aristocratic3d Posted August 27, 2013 Author Share Posted August 27, 2013 In that case I will have to setup 84 different scene states. Dunno about the script, but you can use the scene state manager in max (presuming you are working in max?) and render your cameras with scene states defined. Link to comment Share on other sites More sharing options...
