Linear light with IES
Alpenshiva
Hello everyone!
I would like to know how you handle linear lights like LED-Strips or fluorescent tubes in combination with IES files.
There are some producers which offer files for tubes, but they all look similar to a point light.
Is there a possibility to manage this without using vray area lights?
Thank you, Alpenshiva
I would imagine that would be very computationally expensive, but I suppose if I were to do it then I'd draw a spline along where the LED strip would be and use the spacing tool to place IES lights along it at set intervals.
As for strip lights, I really don't see any problem with using a long VRay Plane Light, or even a VRay MeshLight to simulate the shape.
Edited by Macker
Well yes and no.
LED strip lights are made of anything from 1 to hundreds of individual LED lights, so no manufacturer will ever be able to know how you are going to use it in your project and provide you with an IES for it; there are literally infinite possibilities. The only way you will get a physically correct version of it is to find an IES for a single LED light and array that around, thus simulating an LED strip. This would get you pretty damn close to the real thing, as close as you'll ever need to get I'd imagine.
not in max, not really. Mental ray also has a problem with this type of light. they have to interpolate the distribution along a vector which ends up being 'close' but not correct. For correct illumination, you should really use lighting design software and not graphics programs.
