bigbang Posted August 30, 2013 Share Posted August 30, 2013 i have a white scene with detail in corniche same as pic and also i have v-ray setting like pic but as u see in corniche part there is some black spot and i don't have good line detail there . pls help me thx Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 30, 2013 Share Posted August 30, 2013 Splotchiness like that is caused by your GI. Either of these should work; 1) Enable "detail enhancement" on your irradiance map rollout. 2) Render using brute force as a primary GI, try using the Vray Universal Settings Link to comment Share on other sites More sharing options...
bigbang Posted August 30, 2013 Author Share Posted August 30, 2013 tnax chris but i did 2 way but agine it dosent seems pure white with good ditail . do u have any other idea ??? tnx Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted August 30, 2013 Share Posted August 30, 2013 For white cornice details, you should go for ADAPTIVE DMC, try it on 2/6 or 1/8 Link to comment Share on other sites More sharing options...
bigbang Posted August 31, 2013 Author Share Posted August 31, 2013 Tanks Zdravko . I did that but still same . no change . Link to comment Share on other sites More sharing options...
CliveG Posted September 1, 2013 Share Posted September 1, 2013 How about an AO pass for added definition of the cornice. It won't help with any of the dots or splotches, but may help show more of the detail. Link to comment Share on other sites More sharing options...
bigbang Posted September 1, 2013 Author Share Posted September 1, 2013 hi i did not get the meaning of AO pass . could u pls explain more for me . Tanx Link to comment Share on other sites More sharing options...
Chris MacDonald Posted September 1, 2013 Share Posted September 1, 2013 Try the universal settings and report back. If they don't work then it is a problem with your geometry. Link to comment Share on other sites More sharing options...
CliveG Posted September 1, 2013 Share Posted September 1, 2013 With regards to AO - it means Ambient Occlusion - there are a few different ways of achieving this depending on your render engine. But a search of old posts here should provide you with all of the information you may need for your render engine. This will only add a bit of definition to your cornice moulding, it won't cure your other problems, you'll need to refer to the other answers for that.... Hope this helps. Link to comment Share on other sites More sharing options...
bigbang Posted September 1, 2013 Author Share Posted September 1, 2013 ok tanx all for your answers . Link to comment Share on other sites More sharing options...
