dharmaone Posted August 30, 2013 Share Posted August 30, 2013 Is it possible to get a vray render node up and running on a linux server? I'm thinking about renting one of these anyway for a web dev playground http://www.ovh.co.uk/dedicated_servers/ Would like to use it occasionally to help with the speed of my vray renders. The machines have really high specs (up to 8 cores, shitloads of RAM), decent prices (under £100 a month), and you pay monthly - so if you don't need it later you're not tied in to a contract Any thoughts? Link to comment Share on other sites More sharing options...
dharmaone Posted August 30, 2013 Author Share Posted August 30, 2013 just noticed that you can install windows 2012 server on these for £17/month. Their cheapest i7 (2.66ghz bloomfield 24gb ram) is £30/month, so for £47/month I could have an i7 windows server. Would 3ds max Vray render nodes be possible to set up on this setup? Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted August 30, 2013 Share Posted August 30, 2013 A "Bloomfield" i7-920 @ stock 2.66GHz speeds has a Cinebench 11.5 score of ~4.8pts under Win64, and it will cost you around £564 / year. A FX-8350 rendering node with 16GB of Ram can be had for less than £350 before OS, and has a Cinebench 11.5 around ~6.9 pts. 32GBs. A 3770K would do ~7.6 A 4470K would do ~8.1 Both Ivy Bridge and Haswell i7s can be had in 16GB configs for less than £450 before OS. Ofc all the above can be upgraded to 32GBs if you wish so, and you would still be around the price you would pay for a server utilizing 2008 mainstream technology. You could even overclock your own nodes mildly, and gain even more substantial gains over a 920...almost double the speed. I would rather have my own little node, which I could upgrade at will, repurpose or sell if I don't use, even at a loss - all the money you will be spending on renting one cannot be recuperated at any %. Even if you will end up getting the server for your side-web-dev thing, I don't know how viable it will be using it as a remote rendering node regardless. Uploading assets/models to the remote server might take ages depending on your connection to the webs, while a local machine, even over wifi would work and be managed much much faster. Link to comment Share on other sites More sharing options...
