bwilson Posted October 13, 2004 Share Posted October 13, 2004 Hello All, I am rendering a quite large interior scene originally created as 7 XREFS then meged into one file for the radiosity calculation. Problem is everytime process the radiosity and save, when i reload the solution becomes invailidated everytime. Then frames render on the farm with the incomplete solution for lighting. Any thoughts? Specs: Max 5.1, 3p P4, 1G RAM, Scanline renderer, radiosity, phootmetric lights. Scene is 1.6 Million polygons. Link to comment Share on other sites More sharing options...
abicalho Posted October 13, 2004 Share Posted October 13, 2004 What do you mean the frames render with the incomplete solution? An invalid radiosity is not a problem for rendering, unless the mesh is different at render time. Different Viewport x Rendering values are a problem and are the main reason why Radiosity is invalid. Alexander Link to comment Share on other sites More sharing options...
bwilson Posted October 13, 2004 Author Share Posted October 13, 2004 i think that is what is happening. Somehow the mesh is changing when i reload the scene. Looks great when i render the scene after the solution is created, but when i save, then reload i get a message that the solution is invalid, and it renders only the direct lights Link to comment Share on other sites More sharing options...
abicalho Posted October 13, 2004 Share Posted October 13, 2004 Did you merge/bind the Xrefs? If the objects are still Xrefs, they won't render correctly and things will not work. Alexander Link to comment Share on other sites More sharing options...
bwilson Posted October 16, 2004 Author Share Posted October 16, 2004 Hey Alex, I did as a matter of fact, checked all the XREF Objects and Scenes, all were clear... I wound up setting up multiple camera NetRenders immediatly after i generated the solution and got it to work just in time to meet the DL! Thanks for the help everyone. Link to comment Share on other sites More sharing options...
