TomD_Arch Posted August 30, 2013 Share Posted August 30, 2013 Lets say I have an object or plan brought in on a .dwg. The angle is some rational number (23.76 degrees). I need to use a Helper Grid. I can get the grid snapped to a corner of my object and now I want to rotate the grid to align with the object. How do get the rotating grid to snap so it is in perfect alignment? Link to comment Share on other sites More sharing options...
Jose Negrete Posted September 3, 2013 Share Posted September 3, 2013 use autogrid while placing the helper grid Link to comment Share on other sites More sharing options...
TomD_Arch Posted September 4, 2013 Author Share Posted September 4, 2013 Actually, I have found that with a little tinkering and becoming familiar with the ALIGN tool I am able to align the grid perfectly. Jose- Thank you for enlightening me to the autogrid, that will come in handy too! Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted September 4, 2013 Share Posted September 4, 2013 You can also just draw a line between 2 points and then extrude it. Then draw a Box. Use the Normal Align tool to align one side of the box to the extruded line. You can now copy and paste the rotation transform onto your Helper Grid and know that it is exactly right. Link to comment Share on other sites More sharing options...
Jamie Cardoso Posted February 21, 2014 Share Posted February 21, 2014 (edited) Hi Thomas, Please check the following post below. It should help solve the above mentioned problem (e.g. the relevant section of the tutorial starts from "Create and snap a grid helper perfectly to any given geometry and/or spline, in any angle": http://jamiecardoso-mentalray.blogspot.co.uk/2013/09/essential-tips-tricks-for-vray-and.html Ta jamie Edited February 21, 2014 by Jamie Cardoso Link to comment Share on other sites More sharing options...
miauu_u Posted March 6, 2014 Share Posted March 6, 2014 Or you can try with Work Plane script for 3ds Max. Link to comment Share on other sites More sharing options...
