Muti sub object materials with AEC objects
philvanderloo
http://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-Help/index.html?url=files/GUID-36451AEB-2E65-44E1-893D-9627F261AA3C.htm,topicNumber=d30e32205
"By default, 3ds Max assigns five different material IDs to windows. The aectemplates.mat material library includes Window-Template, a Multi/Sub-Object material designed to be used with windows. Each component of the window/material is listed below along with its corresponding Material ID. "
That materials library is in the materiallibraries folder inside your Max directory in your Program Files/Autodesk folder. If you are using Vray you will have to convert all the standard materials in the aectemplates.mat library to V-Ray. Best resave the library after as for example vray_aectemplates.mat
Edited by Ismael
typo
Thank You Ismael.
I've read through all of this and it all makes sense but I still can't figure out why, when I convert my AEC window to an editable mesh, and select certain faces and apply multi/sub object materials, the materials apply to the entire window. Not just the selected faces. I've tried 2 or 3 different methods and I can't get the materials to apply to individual faces??
Ok I'm editing this post to say that this video was very helpful-
Edited by philvanderloo
