How to render windows of the Buildings with wireframe?
maxdesigner
That is a combination of Spandrel Glass, Vision Glass, and Mullions.
Spandrel and Vision Glass are largely the same just one is more transparent than the other, just use either Diffuse Color, Fog Color, or simply Photo Filters in post to achieve the color. Mullions are a sparate object that are usually metal.
http://tinyurl.com/nwa9455
http://forums.cgarchitect.com/74105-glass-final-frontier.html
I think you're asking how to make reflective materials, like glass, in vray? You start with the basic VRayMtl shader. See the Vray Help for descriptions of the settings: http://help.chaosgroup.com/vray/help/200R1/material_params.htm
The basic way to make glass is to combine reflection with refraction. How much or how little of each will depend on your lighting and environment set up. A quick way of getting environment reflections on building exteriors is to load an HDRI map into the Environment Reflection slot in VRay render settings. http://help.chaosgroup.com/vray/help/200R1/render_params_environment.htm
For wireframe, look at the VRayEdgesTex map: http://help.chaosgroup.com/vray/help/200R1/vrayedgestex_params.htm
This will render only edges of the model with lines in the color and thickness of your choosing.
Good luck and happy rendering!
