spline help in 3ds max
anthonymiller
okay guys you've helped me a lot so far and i think this is my final question. in sketchup when i wand to draw lets say and arched window i use the drawing (spline) tools, using the arch tool and line tool. in max when i want to do the same thing i use connect/slice plane to make the window however when it comes to the arch i get stuck. i go to the line tools in max however i'm not able to draw on the surface in the same way as sketchup. whats the correct way of doing this? are there any plugins that allow direct drawing on an editable ploy like in sketchup?
thanks for the help :D
try drawing arc/circle with autogrid enabled. that should align to surfaces as you draw
*autogrid is a toggle at the top of the "object type" selection area, where you pick line, or arc, or circle. that will make your objects stick to surfaces. i think you can ignore my first suggested method :D
Edited by acad-gatsu
