Bright edges - can't get rid of them
andreeam
Hello!
I would very much appreciate your help. I've got this bright edges every time I render even though I changed the settings so many times, nothing seems to help.
My settings are:
Image sampler:Adaptive DMC, min subdiv:1, max subdiv:8
AA filter: Mitchell- Netravali
GI engine: Irradiance map & Light cache
Vray sun, Hdri with Vray dome & vray light for lamp
Thank you!
Allright, either try to increase the hsph samples and decrease the interp samples to give irradiance map a change to go more detail OR try and check the "check sample visibility" box. Or try both examples. Hopefully it will render better.
If the irradiance map slows down because of this, try a custom setup in which you use min/max as -6/-3. That usually works fine fore me.
Cheers!
For an interior scene as this, a Sun and HDRI with dome is an overkill. It is killing you the superbright outside samples leaking to th edarker interior. See example 4 here: http://help.chaosgroup.com/vray/help/200R1/examples_lightcache.htm#retrace
If you have V-Ray 2 you can use the 'retrace'. Otherwise, knowing what the problem is..., remove the Sun/Dome try just a plane light at the window...
HDRI with vray sun/sky is overkill as mentioned. It also increases render times in my opinion.
In my experience. the problem you have is due to poor GI. Ensure you follow the advice given above and do the following which almost always helps with light leaks.
go to vray render setup under global switches, under raytracing change secondary raytracing value to 0.001 and then under light cache check 'retrace threshold' and enter the value of 1.0.
good luck
