gabmass Posted September 17, 2013 Share Posted September 17, 2013 guys, could you tell me for a professional architectural lighting scope., learning photometric is a plus? or a must !? any chance that standard lighting of 3Ds Max, could have any unique lighting privileges rather Vray Light and Photometrics!? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted September 17, 2013 Share Posted September 17, 2013 You should get a big coup of coffee or tea, seat in a comfortable chair and read the Help website of VRay for 3dMax, there is tons of information and samples regarding this and other questions that you may have, also the help info within 3dsMax is full of examples and explanations. This question is easy to answer just knowing the basic concept of the tool. Each light has it pro and cons, VRay is a plugin software created to work with 3dsMax, the main idea is an optimized tool to make great and fast renderings, in theory you should use only VRay elements to make the whole system work efficiently, but of course in some cases this can't not be applied or is not that strict. VRay is smart enough to be compatible with most of the default tools of 3dsMax. 3dsMax lights are simple with tons of options, VRay Lights render faster, but sometimes they don't have the same options that standard lights. Review your concepts so later you can answer the next obvious question that will come to you. What are the best setting to get a good render in VRay? Cheers Link to comment Share on other sites More sharing options...
Ismael Posted September 17, 2013 Share Posted September 17, 2013 http://www.ies.org/ Link to comment Share on other sites More sharing options...
dhammikaherath Posted September 17, 2013 Share Posted September 17, 2013 You made me dizzy… Link to comment Share on other sites More sharing options...
gabmass Posted September 24, 2013 Author Share Posted September 24, 2013 lol . why ? dhammikaherath said: You made me dizzy… Link to comment Share on other sites More sharing options...
gabmass Posted September 24, 2013 Author Share Posted September 24, 2013 that helps thanks a lot. fco3d said: You should get a big coup of coffee or tea, seat in a comfortable chair and read the Help website of VRay for 3dMax, there is tons of information and samples regarding this and other questions that you may have, also the help info within 3dsMax is full of examples and explanations. This question is easy to answer just knowing the basic concept of the tool. Each light has it pro and cons, VRay is a plugin software created to work with 3dsMax, the main idea is an optimized tool to make great and fast renderings, in theory you should use only VRay elements to make the whole system work efficiently, but of course in some cases this can't not be applied or is not that strict. VRay is smart enough to be compatible with most of the default tools of 3dsMax. 3dsMax lights are simple with tons of options, VRay Lights render faster, but sometimes they don't have the same options that standard lights. Review your concepts so later you can answer the next obvious question that will come to you. What are the best setting to get a good render in VRay? Cheers Link to comment Share on other sites More sharing options...
gabmass Posted September 24, 2013 Author Share Posted September 24, 2013 I just thought there might be someone who's experienced architectural lighting so he can give me tips to follow the best pathway towards all the options available. Link to comment Share on other sites More sharing options...
AJLynn Posted September 24, 2013 Share Posted September 24, 2013 What exactly are you trying to do? Interior lighting design? Do you need exact numbers for the lighting on surfaces, or do you just need images to present a design? And what software do you currently have? (What Max version, is this a Revit thing, etc.) Link to comment Share on other sites More sharing options...
gabmass Posted September 24, 2013 Author Share Posted September 24, 2013 I'll post up questions in particular problems in forum so to have all neeeded explained. thanks AJLynn said: What exactly are you trying to do? Interior lighting design? Do you need exact numbers for the lighting on surfaces, or do you just need images to present a design? And what software do you currently have? (What Max version, is this a Revit thing, etc.) Link to comment Share on other sites More sharing options...
