Onzki Posted October 4, 2013 Share Posted October 4, 2013 Hi everyone, I am coming from CAD and Sketchup modeling environment, so I'm a newbie to 3D max modeling workflow (edit poly). In CAD and Sketchup I am fond of changing the axis to align to a specific orientation or follow the object's orientation, an effective technique that I got used to. Is it possible to do this in 3Ds Max? I have screenshot below for reference. My Story: The problem started when I noticed that everytime I move a vertex from left side view, strictly along X and Y only, when I looked at it on Top view, I discovered that the vertices are no longer in line with the orientation I am keeping. I discovered that the problem is due to the axis not being aligned to the object. That's why it wouldn't align properly. If I can only realign the axis to the object, that will help me a lot. Thanks! Jon Link to comment Share on other sites More sharing options...
Jose Negrete Posted October 7, 2013 Share Posted October 7, 2013 change your reference coord system to local, or create a helper grid at that angle and activate it, then change ref coord system to grid. Link to comment Share on other sites More sharing options...
salvador Posted October 7, 2013 Share Posted October 7, 2013 (edited) The fast solution for your specific question is simple. Go to your Reference Coordinate System drop-down (Top toolbar on your UI) and select "Screen" from the list; this will force transformation to the current view on your current viewport. However, there are many ways to restrict transformations depending on your workflow. I suggest googling for this. Edited October 7, 2013 by salvador Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 7, 2013 Share Posted October 7, 2013 Draw a rectangle in the front view, collapse to edit spline, attach your custom line, and delete the rectangle. This will set your line orientation to what you want. Link to comment Share on other sites More sharing options...
Onzki Posted October 13, 2013 Author Share Posted October 13, 2013 Hi Guys, thanks a lot for your suggestion.. I'll give them all a try. I discover another related method which is inside the dialogue of transform pivot- the edit /use working pivot tab. It's a lot time consuming and needs more learning for me As I think this through, maybe I can just leave 3D max standard workflow the way it is (axis unchanged) and adjust my own workflow to suit it by creating each piece of my model separately and then just assembling them in one file using import or block proxy's. Link to comment Share on other sites More sharing options...
