TomA Posted October 7, 2013 Share Posted October 7, 2013 Is it possible to achieve the look of this physical model (courtesy of Dow Jones Architects) in Vray, in terms of lighting and materials? If so, how? Thanks in advance Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted October 7, 2013 Share Posted October 7, 2013 (edited) My guess would be to create paper/cardboard materials, scale your model to the size it would be "in real life", apply materials, apply lights and then hit render? Also make sure you apply a lot of DOF to your image, as it helps to create the illusion that your model is in fact small. Edit: For the miniature model effect, you may also wish to check out some tutorials on how to fake tilt shift photography in photoshop. I am not sure if you can achieve it with a vray physical camera. Basically it is an effect you can achieve with special lenses on cameras so that full size/real life stuff looks like small models. So that might be a neat trick to convey that your model is small. Edited October 7, 2013 by nicolaibongard Link to comment Share on other sites More sharing options...
TomA Posted October 7, 2013 Author Share Posted October 7, 2013 Great ideas thanks. I will be trying them out. Any tips for the lighting and render setup, anyone? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted October 7, 2013 Share Posted October 7, 2013 Depth of field is the magic sauce that makes things look miniature. The more you exaggerate DoF, the smaller things look. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted October 7, 2013 Share Posted October 7, 2013 As Nicolai mentioned, look into the tilt-shift effect. That really makes things that are real look miniature. Link to comment Share on other sites More sharing options...
heni30 Posted October 7, 2013 Share Posted October 7, 2013 Here are some nice samples. If you just google tilt-shift - it's a widespread photography happening thing right now - you'll find a lot of info. http://www.smashingmagazine.com/2008/11/16/beautiful-examples-of-tilt-shift-photography/ Link to comment Share on other sites More sharing options...
TomA Posted October 7, 2013 Author Share Posted October 7, 2013 (edited) Nice links thanks. I remember the effect was used in The Social Network at the start of the rowing scene on the Thames. Edited October 7, 2013 by TomA Link to comment Share on other sites More sharing options...
heni30 Posted October 7, 2013 Share Posted October 7, 2013 I would do it in Photoshop - faster and a lot more control. Just place a blurred copy on top of the original and start erasing away with hard and feathered brushes. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted October 7, 2013 Share Posted October 7, 2013 I would do it in Photoshop - faster and a lot more control. Just place a blurred copy on top of the original and start erasing away with hard and feathered brushes. Perhaps, but it doesn't look as good as real depth of field. Sent from my HTC One using Tapatalk 2 Link to comment Share on other sites More sharing options...
Scott Schroeder Posted October 7, 2013 Share Posted October 7, 2013 Photoshop CS6 has a tilt-shift lens effect built in. Filter -> Blur -> Tilt-shift. Link to comment Share on other sites More sharing options...
AJLynn Posted October 7, 2013 Share Posted October 7, 2013 Tilt-shift is just a way of faking small DOF that you can use if you have a real camera and are trying to make something that's actually large look small. For making your render look like a model, make it like it's a model. Make it small, make materials like a physical model is made from, put it on a base and put in a fabric background and studio type lighting. Add DOF if you want but if you do the rest it's not even needed. Shoot views like those you would use if you had a model and a DSLR. I don't like the shot you've shown here for that reason. It looks like a shot taken in a real building that's got very odd furniture. Maybe some sort of art installation designed by a sleep deprived architecture student. Here's an example. Simple, but it was effective in selling the project to the client. Link to comment Share on other sites More sharing options...
heni30 Posted October 7, 2013 Share Posted October 7, 2013 (edited) Perhaps, but it doesn't look as good as real depth of field. Actually an overall radially graded erasure of a blurred copy over a sharp image will give the exact same look as a camera dof. But some of the most effective t&l images are not uniform and perfect. There's a kinda clumsiness/heavy-handedness to them which makes the subject matter look even more like a small model. Edited October 7, 2013 by heni30 Link to comment Share on other sites More sharing options...
Chris MacDonald Posted October 7, 2013 Share Posted October 7, 2013 Actually an overall radially graded erasure will give the exact same look as a camera dof. But the some of the most effective t&l images are not uniform and perfect. There's a kinda clumsiness/heavy-handedness to them which makes the subject matter look even more like a small model. Not without some very serious scrutiny. I think there is a common misconception that dof simply blurs the edges of an image: it doesn't. It takes into account how far away objects are from the focal point, Photoshop does not unless you are using a plugin & zdepth pass. Sent from my HTC One using Tapatalk 2 Link to comment Share on other sites More sharing options...
heni30 Posted October 7, 2013 Share Posted October 7, 2013 You're right. A radial erasure assumes that everything in the middle is far away and the edge stuff is close which is what the OP's example is doing. But let's say the right wall ended in the foreground and the back wall continued to the right of it -then it wouldn't work. Link to comment Share on other sites More sharing options...
AJLynn Posted October 8, 2013 Share Posted October 8, 2013 You can't just say that the center of the screen will be in focus and the outside won't. The center area has both foreground and background and so do the edges. The amount that a part of the scene will be blurred relates to the distance from the plane or curve of focus. If there is an edge of a foreground object that's in focus and the background is not, it will go from sharp to blur and the in focus object will "pop" out. Highlights in the background will be circles, with the quality of those depending on the lens. You can't easily fake this stuff well enough to make it look good. And it still doesn't solve the problem of the original image posted looking nothing like a model photo. Link to comment Share on other sites More sharing options...
Tommy L Posted October 8, 2013 Share Posted October 8, 2013 (edited) As Nicolai mentioned, look into the tilt-shift effect. That really makes things that are real look miniature. I absolutely love the Hulk Hogan bit. Oh, and to answer the question... 2 options, either render the DOF (more realistic but less flexible) or do it in post (greater control, less render tme, can have opacity and specularity errors). I would test it both ways at low res and see which you prefer. the other thing to consider is what post production tool you will use. The lens blur in PS is horrible, just looks fake no matter how much you fiddle with it. I'd recommend DOF Pro from Richard Rosenman or Frischluft in Aftereffects. Neither are free, both are a steal. Oh, and in response to the 'clone the layer, blur then pint out a mask' idea...well that wont work but you could manually paint a ZDepth as a controller, that is probably the best way to tilt shift a non-tilt shifted photo sequence... Edited October 8, 2013 by Tommy L Link to comment Share on other sites More sharing options...
theoengelbrecht Posted October 10, 2013 Share Posted October 10, 2013 Hi Guys, first post here so lets give it a shot, i had a look at Tom's reference image and i notice two things, the ugly overexposure of the top window area that has nothing to do with this whatsoever but just felt like mentioning it. and the horizontal lines in the corners is straight up, which means there is a vertical shift applied to the vray physical camera which might also contribute to the illusion of the tilt shift effect, Photoshop tilt shift is not very versatile, the "Smallworlds Video" is a bit more complex and the blur differs alot from scene to scene and photoshop just slaps it on there making it quite messy, anyway I was bored earlier and remade a similar scene trying to mimic the effect and post was done entirely with 2 additional Vray render elements, Extratex with dirt map for ambient occlusion, and Zdepth that i used the most to enhance the environment effect from the windows and the blur effect seen on the picture, didnt take long, was just a test since i was curious. But usind Zdepth in post is very versatile and easy to use not to mention the render time saved. Link to comment Share on other sites More sharing options...
theoengelbrecht Posted October 11, 2013 Share Posted October 11, 2013 I noticed two things, the over exposure to the top part, something i always use in my architectural renders and that's the vertical shift applied to the vray physical camera since the corners of the room looks is straight upright, that may compliment the illusion of the tilt shift effect too? I think FOV also has alot to do with this. Anyway i made a quick scene to mimic this and i found that in post you can do alot with only the ZDepth render element, attached is the render, also Tom A, if you want i can send you the psd and scene file if this looks like what you are after then you can have a look see. Link to comment Share on other sites More sharing options...
