Creating shape in 3ds Max
efilana
Hello guys!
Can you help me create this shape in 3ds Max? I need the purple curve to be extruded along the pink curve. How do I do that?
I am not sure that picture is rendering, but basically it would be imitation of Rhino command "extrude along the curve"
Thanks
Efilana
Try the sweep modifier.... there is an option to use a custom profile.
Indeed, also make sure your purple curve's pivot is located at the vertex where both curves meet and that it's aligned to the plane that the purple curve is describing. . . now sweep away !
Hey guys, thanks for your help. I was able to sweep, and I loved that you can control path, this is great.
however, I ran into this issue: my exit profile (the purple one) was different then the initial purple curve. Can I control that one, too? I would like to have a shape that has both profiles the same.
