Arch&Desing black bitmaps. Please help.
Hello, I've been playing around with Mental Ray Arch&Design material templates but found an issue I've been trying to solve without any luck. The bitmaps for each template are black (please see image attached) it seems the directory for these bitmaps has move and Arch&Desing can not find it. How can I repair this issue.
I'm using 3ds max 2011 (no design). The renderer is Mental Ray.
Please any help is appreciated.
This isn't really the forum for this, but...
Your bitmaps are showing as black because, as you noted, the JPG files aren't where you need them so Max can't create the bitmap map. You can use file search on your PC to try and find them, or copy the missing folders from another PC, or reinstall the software.
